i am trying to make a welder from an alternator.i have a bridge diode,and a circut board made to control up to 150 amps.does anyone have an idea or drawing as to how to hook up field power.all of the ones i have read about control current by engine speed or by adjusting voltage going to field.i want to control amperage with circuit board after 12 volts is applied to field.will this work? would i also need an on-off switch on field supply wire.i have read almost every welder alternator write up on the web,most are onboard welders and i want mine to be portable with a seperate engine driving the alternator.i have a 13 hp engine that i will be using.does anyone have a drawing or could make up a drawing with every detail included as i don't read electrical drawings well.Thank-you
