Alternator and bulb config proteus
MrYu
how's the configuration of the alternator and bulb in proteus?
i try this schematic in proteus but the bulb have no light
Is the LDR a ORP12 or similar?
In low light levels the LDR could be 10 Meg Ohm and hence no light. Is this the way you wanted it?
Hi MrYu,
your circuit should work well if you use appropriate power supplies for both, the low voltage and the mains voltage part.
Using any phantasy-power source won't suffice for a successful simulation. Select an AC power source for proper simulation.
You might also use a proper device to simulate the LDR with light source.
Your circuit wastes one transistor!
You have two options to reverse action by putting the LDR from the base towards ground or from the base towards the positive rail of the device.
Have a look at my simulation results, one with the light bulb on and the other one with it off.
Boncuk
