I have a fairly old Honda stereo that only has a tape player and a proprietary auxiliary input connector. I could not find pin information for the aux input connector and I assume it has circuitry to detect a proper load before allowing the stereo to be switched to aux input mode. Aux input adapters cost over $50. I'm looking to do something cheaper so I can hook my MP3 player or cell phone up to the stereo. I have searched the internet for several hours and could not find a solution for my specific stereo model.
I have identified two possible options.
I could solder my input directly to the amplifier chip. I found a spec sheet for it here. The problem with that is the chip is designed for 4-channel output and unless I want to short two pairs of channels together, I won't be able to solder to it. I also don't know how the pins are numbered.
My other thought was to solder to the left and right channel outputs of the FM demodulation section of the circuitry. The demodulation section is standing vertically and shielded. The left and right channel pins are labeled L and R on the PCB. I tested them using my cell phone to play some music and touched the wire to the L and R pins. I heard the sound, but it had a lot of static. The antenna was not plugged in to the radio and it was not tuned into a station. If I use this method, can I expect the static to go away with a solid electrical connection, or will the antenna's static persist because I am not tuned into a station? This radio is old enough to play static even when there is no signal.
I want to get some good opinions on this before I take the time to solder connections. It is not a friendly circuit to work on and may be difficult to avoid causing an unwanted solder bridge.
