ADC on Junebug
MrDEB
For test purposes I am trying to get Junebug to run an ADC code snippet but Juney won't coperate.
My end usage is to use a CDS or photo-transistor to detect day/ night which will enable several LEDs running a PWM code.
Got the PWM working but getting the ADC to work?
using VR1 (connected to RA1 as my input and outputting to A0
have A6 low so A0 can light
Include "ADC.bas"                   // Include the ADC.bas library  you had this  / Include "ADC.bas" didn't need the backslash
Dim LED0 As PORTA.0                  // Declare the LED pin
//Dim LED1 As PORTB.1
Dim LED2 As PORTA.6
Dim result As Word
Function Get_ADC_Sample() As Word   // Function to grab the ADC sample
   result = ADC.Read(1)             // Grab an ADC sample from channel 0
  result =result * 2              // Scale the answer up by a factor of 2
End Function
OSCCON = %01110110                 // Setup the internal OSC for 8Mhz
Input(PORTA.1)  // Make AN1 an inputconnected to VR1 on junebug
 PORTA.6=0
 //result =0     // clears Aresults
//While True                         // Create an infinate loop
//If Aresult > 128 Then
  // High (LED0)
//EndIf
 //Wend
while True                         // Create an infinite loop
If Get_ADC_Sample > 128 Then
   High (LED0)
EndIf
Wend
