ADC does't work
Tymoty
Hi, I try convert voltage from MMA7260Q and show on lcd but it doesn't work. this is my code
g1=0;
g2=0;
ADCON0bits.ADON=1;
_asm NOP _endasm
_asm NOP _endasm
ADCON0bits.GO=1;
ADCON0bits.CHS0=0;
while(ADCON0bits.GO!=0);
osaX=(ADRESH*256) + ADRESL;
ADCON0bits.ADON=1;
_asm NOP _endasm
_asm NOP _endasm
ADCON0bits.GO=1;
ADCON0bits.CHS0=1;
osaY=(ADRESH*256) + ADRESL;
PutMessage((rom char*)"\x16\x0\x8 X:");
PutMessage(osaX);
PutMessage((rom char*)"\x16\x0\x24 Y:");
PutMessage(osaY);
and before this in main.c
ADCON0=0x00;
ADCON1=0x0D;
ADCON2=0x95;
and on senzor is voltage about 1,65V(axes x,y) and when i connect mcu voltage is cca 0,2V. i don't know why
Assuming you are using my GLCD code, you have a few problems here. The PutMessage routine only works with strings that are stored in ROM, your 0azX is not a string and is not stored in ROM. The way to fix this is to write a new function that will print an integer.
A simple version would be,
void PutInt(unsigned int num){
    PutChar((num/1000)%10+0x30);
    PutChar((num/100)%10+0x30);
    PutChar((num/10)%10+0x30);
    PutChar((num)%10+0x30);
I have not checked your ADC code but it looks like you don't leave enough acquisition time.
adc 10bit 1010110101
ADRESH*256 + ADRESL = ?
xxxxxx10 in adresh = 2 = 2*256 = 512
10110101 in adresl = 181 + adresh "512" = 693
so 10 bit adc result from 1010110101 = 693
Csaba
Thank you pommie, your code running great. I had mystake in configuration of trisa (i use ra0 and ra1 and i had ra6 and ra7).
and pommie I hope that I can use your glcd routine. I use this for my school project and of course I write you like author. but I need some info about you, I can't write to my project - routine from some forum from pommie :)
thank you
Feel free to use my code, it is in the public domain and so that should make it acceptable. If you have any problems with citation then I can give you additional information.
