this program will read an analog i/p from a pot and display its binary equivalent on portb leds and then converted for the lcd and when im changing the pot resistance it is incrementing by 51 everytime and will make this pattern twice till i switch it on fully that is the pattern is this: o, 51, 102, 153, 204, 255, 51, 102, 153, 204 and 255 again.
can someone help me see whats wrong with it?
//This is a Test Program to read analog i/p CH_0 Pin_2
//and display the binary equivalent on PORTB LEDs. Also,
//the value is converted to DECimal & ASCII respectively
//to be displayed on a 16x2 LCD.
//Pin_5 Vref+ must be connected to +5V.
//Header file for PIC Micro’s
#include<htc.h>
//Set Configuration Fuses PIC16F877 from Software
__CONFIG (0x3F72);
//define ports for easier reading
#define LEDS PORTB
#define LCD PORTD
#define RS RC0
#define R_W RC1
#define EN RC2
//Prototype Functions declared here
void swait(unsigned char itime);
void cmnd(unsigned char *patt, unsigned char lenght);
void dat(unsigned char *patt, unsigned char lenght);
void dat_2(unsigned char value);
void USDELAY(unsigned char utime);
void MSDELAY(unsigned char mtime);
//Main Function Block
void main(void)
unsigned char cmds[4]={0x38,0x0C,0x01,0x80};
unsigned char mess_1[12]="TEMPERATURE:";
//line 2,pos.5
unsigned char cmdl2p5[1]={0xC5};
//line 2,pos.6
unsigned char cmdl2p6[1]={0xC6};
//line 2,pos.7
unsigned char cmdl2p7[1]={0xC7};
//line 2,pos.8
unsigned char cmdl2p8[1]={0xC8};
//line 2,pos.9
unsigned char cmdl2p9[1]={0xC9};
//8bit data-type variables
//store of ADC low byte
unsigned char x;
//store of ADC high byte
unsigned char y;
//store final ADC result
unsigned char value;
unsigned char value2,a,n;
unsigned char dec1,dec2,dec3;
unsigned char units,tens,hundreds;
//make Port B o/ps
TRISB=0x00;
//make Port A i/ps
TRISA=0xFF;
//make Port D o/ps
TRISD=0x00;
//make Port C o/ps
TRISC=0b00000000;
//clear/switch off LEDS
LEDS=0xFF;
//Initialise LCD
//4 elements in cmds array
cmnd(cmds,0x04);
//Send message to LCD
dat(mess_1,0x0C);
//display deg
cmnd(cmdl2p8,0x01);
dat_2(0xDF);
//display Celcius C
cmnd(cmdl2p9,0x01);
dat_2('C');
//repeat forever loop
while(1)
//ADFM=1, all i/ps analog, +VREF enabled
//Configure the functions of the Port bits
ADCON1=0x81;
//clock/channel select & enable bits
//controls the operation of the A/D module
ADCON0=0xC1;
//no.of loops of 255 loops
//wait for acquire time
swait(1);
//Start a2d conversion
//Set GO bit (ADCON0=ADCON0|1;)
GODONE=1;
//wait end-of-conversion (conversion complete)
while(GODONE==1);
//store low byte
x=ADRESL;
//shift 1bit to the right
x=x>>1;
//store high byte
y=ADRESH;
//shift left 7 bit positions
y=y<<7;
//combine high & low bytes
value=x|y;
//output result on PortB LEDs
LEDS=~value;
//make 1st division by ten
//a is first quotion
a=value/10;
//take the 1st remainder LSB
//Units in decimal
dec1=value%10;
//take the 2nd digit/middle
//remainder Tens in decimal
dec2=a%10;
//take the 3rd digit MSB
//Hundreds in decimal
dec3=a/10;
//make units digit ASCII
units=dec1|0x30;
//make tens digit ASCII
tens=dec2|0x30;
//make hundreds digit ASCII
hundreds=dec3|0x30;
//display
cmnd(cmdl2p7,0x01);
dat_2(units);
//display
cmnd(cmdl2p6,0x01);
dat_2(tens);
//display
cmnd(cmdl2p5,0x01);
dat_2(hundreds);
//micro stop here
//while(1){};
//Function to send Commands to LCD
void cmnd (unsigned char *patt, unsigned char lenght)
unsigned char i;
for(i=0;i<lenght;i++)
LCD=patt[i]; //get value from array
RS=0; //for command
R_W=0; //for write
//H-to-L Pulse required
EN=1;
USDELAY(70); //?us delay
EN=0;
MSDELAY(100); //give display some time
//Function to send Data to LCD
void dat (unsigned char *patt, unsigned char lenght)
unsigned char i;
RS=1; //for data
R_W=0; //for write
EN=1;
EN=0;
MSDELAY(10); //give display some time
void dat_2 (unsigned char value)
LCD=value;
RS=1; //for data
R_W=0; //for write
EN=1;
EN=0;
//some delay needed
unsigned char i,j;
for(i=0;i<itime;i++)
for(j=0;j<255;j++);
//used for LCD ENable Pulse
void USDELAY (unsigned char utime)
//8-bit data type variables
unsigned char i;
//single-loop
for(i=0;i<utime;i++);
//used for in between Characters
void MSDELAY (unsigned char mtime)
unsigned int i,j;
//nested for-loops
for(i=0;i<mtime;i++)
for(j=0;j<455;j++);
