ACER Monitor won't work with a BUSH Set Top Box
ljcox
I have an ACER model P221W LCD Monitor and a Bush DFTA10HD Set Top Box.
I use the ACER monitor with my computer via the VGA connection and I would also like to occasionally use it to display a TV picture from
the Bush Set Top Box.
The Set Top works with a CHEMEI LCD Monitor via the VGA connection but it will not work with the ACER monitor.
It also works with my TV via the VGA connection.
When I connect it to the ACER monitor via the VGA connection, the screen shows a message "Input signal not recognised" or words to that
effect.
The Bush also has a HDMI output and the ACER has a DVI input, so I connected them via a DVI cable & HDMI converter. But the same message
appeared on the screen.
Does anyone know why? I assume it is due to incompatible DDC data.
Any assistance will be appreciated.
