accessing of external data memory
bleach
can u please explain me how the accessing of external data memory happen with graph if possible. in μc 8051
thanks
its not that much clear in my book, and i read in other book, i couldn't understand so that's why am asking.
regard
AD0 to AD15 is the address bus. AD0 to AD7 is also the data bus.
The address is put on the address bus. The latch is enabled. Then the data is put on the data bus and read by the micro.
here i have address from AD0 to AD7 connected to the latch circuit and at the same time to the EPROM, so in which one the address will be put.
what i know is the address A0 - A7 is low byte and A8-A15 will be high byte, but why?
how the data will be put on the data bus (do u mean it will be put by the EPROM?
thanks
The low byte of the address goes though the latch. The high byte is connected directly as you can see. Port 0 then becomes the data bus and reads the output byte from the EPROM.
So the address bus is 16-bits wide.
  • Like
Reactions: 3v0
thanks
do u mean port0 send only address in low byte to the latch not data
and after latching the address it read the data from EPROM
i mean how p0 becoum data bus and why send address first then data,?
also
what do u mean....
thanks
Yes because an EPROM can't be written to. Read the link I gave you, it describes accessing both external code and data memory.
The address of the memory location needs to be put on the address bus or you won't be able to access it. Google "address bus".
what do u mean....
It's a 16-bit address bus. It can't be simplified any more than that.
