AC power line communication
gehan_s
Hi all,
I am a third year EE student who has to do a final year project. I am thinking of doing a project on the above topic. The idea is to use power line communication to control devices (home or factory appliances) and for data acquisition.
The problem is I have no previous knowledge on this regard. Can someone help point me in the right direction and tell me where to start.
Thanks in advance !!!!!!!!!!!!!!!!!!!!!!
There are already well-established commercial systems available for this. A bit of googling will find them.
The National/TI part LM1893 is a carrier-current transceiver. Check their datasheet. Plenty of info on the net as well.
Make sure that the learning experience does not include one from the AC mains!
Good luck, E
"Make sure that the learning experience does not include one from the AC mains!"
I second that. That is why one should read very carefully the datasheet and follow all the recommendations.
In particular, make sure that you employ "Y" rated capacitors. They are a little more expensive, but could save you from a nasty shock and/or prevent whatever equipment that is connected to your transceiver from frying.
