samcheetah
i have read in books that in a transistor the voltage between two terminals control the current through the third terminal. like in a common emitter (or common source) amplifier the voltage between base and emitter (voltage between gate and source for the case of FET) controls the amount of current in the collector (or drain) terminal. this explains how transfer of resistance occurs in a transistor and why the device is named so.
some people dont like to explain "transistor action" like this. the transistor can also be thought of a current controlled device. in that case the current in the base controls the current in the collector.
now for my question.
in a common collector configuration what is the situation. the voltage between which two terminals is controlling a current through the third terminal. please explain. thanx in advance
