74LS07N and 7407!
epilot
hello
it seems there is two kind of 7407's
7407 and 74LS07
i want to make a circuit, the IC there is 7407 but i have the LS version i want to see if there is any difference between them????
can i use LS kind?
thanks for any help
epilot said:
hello
7407 and 74LS07
can i use LS kind?
Usually you can without any problem, the LS is a 'better' version, faster and lower power. The only problems that occur is if the original chip was being used in some strange non-standard way? - but this is fairly uncommon with TTL.
Hi Nigle and thanks like always
but i have a data book the exactly thing i am seeing at it now is that 7407 is an buffer but 74LS07 is an invertor buffer?
do you think that the book writing is wrong?
Yes, they are both open-collector inverter buffers.
Would this be for a PIC Programmer?, I've used both the 7407 and the 74LS07 in P16PRO40 designs.
yes it is for this programmer
after unsuccessat the before 16f84 programmer i desided to make this one that is a parallel port hardware too and hop could use from it with winpic and icprog...
This is the exact schematic I used to build my first programmer. It's just the Classic David Tait design with one pull-down resistor added. It's gonna work fine with any 7407...
No. Both 7407 and 74LS07 are open-collector BUFFER. The 7406 is an open-collector inverter BUFFER.
