7-Segment LED Counter (binary and base 10) [Deleted]
Tom McCurdy
Tom McCurdy submitted a new article:
7-Segment LED Counter (binary and base 10) - Here is something that I was able to build, it basically takes the pulse from a 555 timer and goes
Here is something that I was able to build, it basically takes the pulse from a 555 timer and goes through a 7490 divide by 10 into a 7448 and finally into a LN514rk Common Cathode LED-- if you are going to use a common anode LED just replace the 7448 with a 7447
Materials Needed
  • 5 V-Source
    Wires
    555-Integrated Circuit
    7490-Integrated Circuit
    7448-Integrated Circuit
    7-Segment Display (the one I used was LN514RK)
Simply connect it as it is in the diagram...
Read more about this article...
