7-bit binary adder/subractor . how ?
wolvzzz
this is the Logic diagram inside a 7483 4-bit binary adder/subractor ..
hopefuLLy .. somebody wouLd be abLe to give me the equivaLent circuit for a 7-bit inputs :D
a very big big big thanks in advance pro's .. :) :) :) hehehe
+5V
That chip is cascadable to any width in multiples of 4 bits. Why not just use two of them? heh heh
reaLLy ? can you give me the equivaLent cascaded circuit using 2 7483 ? knowing that ,, maybe I can derive that thing using onLy basic Logic gates . I want to impLement it that way because our task is to design a 7-bit binary adder/subractor without using any speciaL kind of ic .. hehehe :D :D
- the mini caLcuLator
+5V
Can't you just cascade 7 . Subtraction implies complementing one of the two inputs, and putting a one to the carry-in of the low order adder.
finaLLy .. i made to design the 7 bit adder using the Logic Ly simuLator .. hehehehehe :D
View attachment 67764 ..
and now with a subtactor . assuming .. when M is Low then ADD , when High then SUBTRACT
if im not mistaken .. can i just XOR the B's with M as a new input for the second operand ? im not too sure though :( :(
+5V
Xor (or maybe its XNor) the seven bits you want to subtract. Wire the subtract control signal M to all seven Xors. Assuming you are doing twos-complement, then the subtract control signal M also goes to the carry-in of the low order full adder.
Ones complement: to negate a number, complement every bit.
Twos complement: to negate a number, complement every bit, and add one.
