Hi everybody,
I really appreciate if someone can help me with this problem:
I'm designing a power supply for an small embedded computer. The computer needs a 5v - 1.2A to work.
I'm using a 6V - 2A transformer, a bridge rectifier, a 3300 uF condenser as a filter and then a L7805 as a regulator.
The circuit works fine without any load. I'm measuring 5.03V on the output. When I connect the computer everything goes fine for a few seconds During the booting process the output voltage drops suddenly to 4.6 causing the computer to restart. When the computer restarts, the output voltage goes to 5 but seconds later, drops again to 4.6 causing the computer to restart again. The current the computer is driving from the power supply at the moment of the voltage dropping is about 850 mA. What could be the cause of this voltage dropping?
Thanks in advance.
Thanks in advance.
