I am trying to build a power inverter using this circuit:
The transformer I have is actually 24v to 120v, it is just temporary right now. And I also dont have the capacitor connecting pin 5 to ground as I didnt think it was neccessary. The problem I am having is that the supply voltage is 12 volts, but the 555 is outputting only half of that (around 6) and I have no idea why because I have never had this problem when using a 555. I thought maybe it was bad so I switched it out for a few different ones, but the problem remains. As a result I am only getting about 5 volts across the transformer so only about 20 volts coming out the other end when it should be around 60. I also tried replacing the whole output with just a resistor and an led, then I was getting about 10.5 volts on the output which I think is about normal. So I think there is something wrong on the output side of the 555 but i just dont know what. Any feedback is greatly appreciated thank you!
