555 timer transistor level
chaluvadi
Hi Guys I Am Doing My Masters In Ee In Utarlington I Need A Project On Counter And Timer Circuits Which Is To Be Implemented At Transistor Level And Has To Be Simulated In Pspice........i Want To Drive The Counter With 555 Timer In Astable Mode.......PLEASE HELP ME GUYSL.........
Choose something more complicated, a 555 timer based project is more typical for the final year of Junior school than a degree.
But he must make an old TTL counter from scratch using millions of transistors.
I would think it would be CMOS.
I am astounded that a Master's candidate would be asking for help from a hobbyists' forum.
Chaluvadi, what part(s) of the project do you need help with?
its not linke that
I have been going through the internet and library for a transistor level 555 timer and counter circuit that can be simulated and spice .......... i have got model of 555 timer with rs flipflops and nand gates ........ i can actually realise them but the schedule i have got is too hectic so.......i dont have a choice but to ask in the forum........
The TS555 datasheet has a schematic. You will have to work out the device sizes.
EDIT: Here is the subcircuit for a CMOS 555. It probably does not represent the TS555 schematic. I make no claims for its accuracy, and I don't remember where I got it.
 .SUBCKT 555C GND TRIGGERbar OUTPUT RESETbar CONTROL THRESHOLD DISCHARGE VCC
* CMOS 555 TIMER
R_R1     CONTROL VCC 150K
R_R2     2 CONTROL 150K
R_R3     GND 2 150K
E_EMIR   VDD GND VCC GND 1
M_M1     DISCHARGE 1 GND GND NCHAN555 L=2U W=1000U
E_EVAL   1 GND 13 GND 1
R_U6_R1  TRIGGERbar 2 1000G
R_U6_R2  TRIGGERbar 2 1000G
E_U6_E1CMP  3 GND 2 TRIGGERbar 10K
R_U6_R3  3 23 10MEG
R_U6_R4  GND 23 10MEG
D_U6_D2CLMP  23 4 DIODE
D_U6_D1CLMP  GND 5 DIODE
V_U6_V2  23 5 dc 0.8V
E_U6_E1  4 GND POLY(1) VDD GND -0.8 1
R_U7_R1  CONTROL THRESHOLD 1000G
R_U7_R2  CONTROL THRESHOLD 1000G
E_U7_E1CMP  6 GND THRESHOLD CONTROL 10K
R_U7_R3  6 21 10MEG
R_U7_R4  GND 21 10MEG
D_U7_D2CLMP  21 7 DIODE
D_U7_D1CLMP  GND 8 DIODE
V_U7_V2  21 8 dc 0.8V
E_U7_E1  7 GND POLY(1) VDD GND -0.8 1
M_U2_U1_M4  9 OUTPUT GND GND NCHAN555 L=2U W=1000U
M_U2_U1_M3  9 17 GND GND NCHAN555 L=2U W=1000U
M_U2_U1_M6  10 9 GND GND NCHAN555 L=2U W=300U
M_U2_U1_M8  13 10 GND GND NCHAN555 L=2U W=250U
M_U2_U1_M1  11 OUTPUT VDD VDD PCHAN555 L=2U W=1000U
M_U2_U1_M2  9 17 11 11 PCHAN555 L=2U W=1000U
M_U2_U1_M5  10 9 VDD VDD PCHAN555 L=2U W=300U
M_U2_U1_M7  13 10 VDD VDD PCHAN555_OUT L=2U W=350U
M_U2_U2_M4  12 18 GND GND NCHAN555 L=2U W=1000U
M_U2_U2_M3  12 13 GND GND NCHAN555 L=2U W=1000U
M_U2_U2_M6  14 12 GND GND NCHAN555 L=2U W=300U
M_U2_U2_M8  OUTPUT 14 GND GND NCHAN555 L=2U W=250U
M_U2_U2_M1  15 18 VDD VDD PCHAN555 L=2U W=1000U
M_U2_U2_M2  12 13 15 15 PCHAN555 L=2U W=1000U
M_U2_U2_M5  14 12 VDD VDD PCHAN555 L=2U W=300U
M_U2_U2_M7  OUTPUT 14 VDD VDD PCHAN555_OUT L=2U W=350U
M_U2_U3_M1  16 25 VDD VDD PCHAN555 L=2U W=1000U
M_U2_U3_M2  17 24 16 16 PCHAN555 L=2U W=1000U
M_U2_U3_M3  17 24 GND GND NCHAN555 L=2U W=1000U
M_U2_U3_M4  17 25 GND GND NCHAN555 L=2U W=1000U
M_U2_U4_M1  18 20 VDD VDD PCHAN555 L=2U W=2U
M_U2_U4_M2  18 RESETbar VDD VDD PCHAN555 L=2U W=2U
M_U2_U4_M3  18 20 19 19 NCHAN555 L=2U W=1000U
M_U2_U4_M4  19 RESETbar GND GND NCHAN555 L=2U W=1000U
M_U2_U5_M1  20 24 VDD VDD PCHAN555 L=2U W=2U
M_U2_U5_M2  20 21 VDD VDD PCHAN555 L=2U W=2U
M_U2_U5_M3  20 24 22 22 NCHAN555 L=2U W=1000U
M_U2_U5_M4  22 21 GND GND NCHAN555 L=2U W=1000U
M_U2_U6_M2  24 23 GND GND NCHAN555 L=2U W=1000U
M_U2_U6_M3  24 23 VDD VDD PCHAN555 L=2U W=2U
M_U2_U7_M2  25 RESETbar GND GND NCHAN555 L=2U W=1000U
M_U2_U7_M3  25 RESETbar VDD VDD PCHAN555 L=2U W=2U
R_U2_R1  RESETbar GND 250G
J_J1     VCC GND GND JNEMOD
R_R6     GND VCC 192K
.MODEL DIODE D RS=0.01
.MODEL PCHAN555 PMOS CGBO=1P CGDO=1P CGSO=1P VTO=-0.2
.MODEL NCHAN555 NMOS CGBO=1P CGDO=1P CGSO=1P VTO=0.2
.MODEL PCHAN555_OUT PMOS CGBO=1P CGDO=1P CGSO=1P VTO=-0.2 CBD=200P
.MODEL JNEMOD NJF VTO=-2.5 BETA=5.12U
.ENDS    555C
*|* CMOS 555 TIMER CONNECTED IN ASTABLE OPERATION
*|.LIB MISC.LIB
*|.PARAM CVAL=20N
*|VRST 4 0 PULSE(1 0 700U 1U 1U 400U 1)
*|C2 3 0 10P
*|VCC 8 0 5
*|RA 8 7 4700
*|RB 7 6 2200
*|C1 6 0 {CVAL}
*|X1 0 6 3 4 5 6 7 8 555C
*|CTRL 5 0 10P
*|.IC V(6)=0
*|.TRAN 10U 800U
*|.PROBE
*|.END
thank u
thanks for ur reply roff............i have got a schematic for 555 timer that is not working and its saying as less than two connections at node i havent figured that out because this was the first time i was using pspice..........the code is as follows............
.SUBCKT UA555 32 30 19 23 33 1 21
* TR O R F TH D V
*SYM=UA555
*DWG=C:\SPICE\555\UA555.DWG
Q4 25 2 3 QP
Q5 0 6 3 QP
Q6 6 6 8 QP
R1 9 21 4.7K
R2 3 21 830
R3 8 21 4.7K
Q7 2 33 5 QN
Q8 2 5 17 QN
Q9 6 4 17 QN
Q10 6 23 4 QN
Q11 12 20 10 QP
R4 10 21 1K
Q12 22 11 12 QP
Q13 14 13 12 QP
Q14 0 32 11 QP
Q15 14 18 13 QP
R5 14 0 100K
R6 22 0 100K
R7 17 0 10K
Q16 1 15 0 QN
Q17 15 19 31 QP
R8 18 23 5K
R9 18 0 5K
R10 21 23 5K
Q18 27 20 21 QP
Q19 20 20 21 QP
R11 20 31 5K
D1 31 24 DA
Q20 24 25 0 QN
Q21 25 22 0 QN
Q22 27 24 0 QN
R12 25 27 4.7K
R13 21 29 6.8K
Q23 21 29 28 QN
Q24 29 27 16 QN
Q25 30 26 0 QN
Q26 21 28 30 QN
D2 30 29 DA
R14 16 15 100
R15 16 26 220
R16 16 0 4.7K
R17 28 30 3.9K
Q3 2 2 9 QP
.MODEL DA D (RS=40 IS=1.0E-14 CJO=1PF)
.MODEL QP PNP (BF=20 BR=0.02 RC=4 RB=25 IS=1.0E-14 VA=50 NE=2
+ CJE=12.4P VJE=1.1 MJE=.5 CJC=4.02P VJC=.3 MJC=.3 TF=229P TR=159N)
.MODEL QN NPN (IS=5.07F NF=1 BF=100 VAF=161 IKF=30M ISE=3.9P NE=2
+ BR=4 NR=1 VAR=16 IKR=45M RE=1.03 RB=4.12 RC=.412 XTB=1.5
+ CJE=12.4P VJE=1.1 MJE=.5 CJC=4.02P VJC=.3 MJC=.3 TF=229P TR=959P)
.ENDS
* Sample Test Circuit for the UA555 Timer: Astable Mode
* The UA555 timer model is designed for low frequency
* applications, up to 100Hz.
*INCLUDE IC.LIB
.TRAN 1MS 100MS 0 25US UIC
.OPTIONS LIMPTS=5001 ITL5=0 RELTOL=.0001
*ALIAS V(1)=VOUT
*ALIAS V(5)=VRESET
*ALIAS V(6)=VCTRL
*ALIAS V(4)=VCAP
.PRINT TRAN V(1) V(5) V(6) V(4)
V2 2 0 PULSE 0 5
R3 2 3 1000
R4 3 4 5000
C3 4 0 .001M
X2 4 1 5 6 4 3 2 UA555
.END
Your model worked for me on LTspice. I don't use Pspice, so I can't help with your problem.
Your shift key appears to be broken.
roff
hey thank u very much man........i had worked it on ltspice and it worked out well ...... can u get me a counter that runs with 555 astable circuit in transistor level........
Not me. As far as I'm concerned, you can do the rest of your homework yourself. If you have a problem other than "Can you get **** for me", we might be able to help. This sounds to me like a case of procrastination, not attending/paying attention in class, laziness, or just plain ineptitude. Maybe I am being too harsh. If you think I'm wrong, you are free to state your case.
vow...
hey ron
u cant say that I had come up with my model and what u have just said is that it worked on ltspice and i cant even figure out how were u able to come to those stupid conclusions ...... any ways its too absurd of u to say that .........this is my last post in this forum and im never even looking into here............
Hero999 said:
Sorry about my previous message (the one before yours, I've just deleted), it was a bit immature and didn't help the situation.
chaluvadi shouudn't be blamed entirely for the above post, it was in response to my immature post. Not that it's any excuse for his behaviour, just because someone provokes you, it doesn't mean you should retaliate.
hi hero,
I think you did the right action by deleting it.
It wasn't up to your usual standard...:)
Oh no, you didn't see it did you? :eek:
Sometimes I really need to manage my anger more effectively.
Didn't Chaluvadi say in his original post (before it was edited) that he must design the circuit himself?
I wonder if his professor is reading his thread about him wanting somebody else to design the circuit for him to just copy.
hi hero,
On a more lighter note.
If you get chance to watch the film called 'Anger Management',,, its a comedy, I think it will make you laugh.;)
IIRC Jack Nicholls stars in it.
