hi, i am using a 555 timer at 51% duty cycle configured as an astable for a frequency of 38khz, for my ir receiver.
now the resistances i used are 180k, from Vcc to pin7 and 16k from pin7 to pin 2and 6. the capacitor i used is 100pf. these values were provided by a 555 timer software i have. now when i test it in reality it gives a frequency of 28khz using my digital multimeter.
when i tested this on my receiver, it never turns active... no matter what the intensity of light and no matter what distance. i am sure that the 555 timer works cause i tried it with a red led first and it did lit up. i then tested the reciver using a pic12f629(with a frequency read by the digital multimeter again of 18khz)(receiver rated at 38khz).. the result is a total succss, it worked perfectly using the pic...
now the only difference it seems that the frequency of the 555 circuit is better than of the pic so i wonder how it did not work at all....
i am very confused since both circuits seem to work and give a frequency but the 555 timer circcuit doesn't work...
(i used a momentarily high switch connected to the reset of the 555 timer so that it works only when the button is pressed, with a red led it shown that this function worked properly....)
any ideas of what might have gone wrong please? thanks a lot
regards
regards
