(50-110v AC)5W inverter from 5v power bank
Moosa Irshad
hiii all,
I am trying to design a circuit to get a 50-110 Ac as output and a maximum of 5W power from a 5V power bank. I am using IC3525 for oscillator , but I have no idea to choose transformer. Hope someone will help me?
We have no idea what skills you have , start by searching this forum for previous answers and web and come up with a more intelligent question , please
Always start with Specs. for every parameter
Hi Moosa Irshad,
Welcome to ETO.
The SG3525AN, KA3525A, and IC 3525 are equivalents. Here is the datasheet for the SG3525: https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.CD00000958.pdf. Unfortunately, this shows that the SG3525 minimum operating voltage is 8V so it will not be suitable for operation from a 5V power bank.
When you say you would like an output voltage of 50V to 110V [RMS], do you mean that you would like the output to be variable between 50V and 110V RMS or do you mean that you would be happy with any fixed voltage between 50V and 110V RMS?
Having said that, a 5W inverter operating from 5V should be good fun and not too difficult to design and make. You ask about suitable transformers: off the top of my head, a standard 10W to 20W 50Hz mains transformer, with a 110V RMS primary and two 3.3V secondaries, should do the job. A couple of power NMOSFETs or possibly a couple of NPN power BJTs should drive the two primaries nicely. The transformer secondary would then provide the 110V output. The frequency drive could be provided by an LM555 timer configured as a free running oscillator set to either 50Hz or 60 Hz depending on your requirements.
You don't say if you need a sine wave output or if a square wave will do. If you need a sine wave you could connect a suitable capacitor across the primaries to resonate with the inductance of the transformer.
Alternatively, if you fancy doing a little programing, a microcontroller could drive the two transistors and possibly generate a sine wave by pulse width modulation techniques.:)
spec
(PS: if you put your location next to 'Location' on your user page we will all be able to see where you are from because it will be displayed in the window on the left of your posts)
