4x4 keypad with LCD - code lock
CrEdo
Hi.
I want to make some basic keypad scanning program with C30 on Pic24 chip.
The program should read keypad press and display the char on LCD.
LCD driver is working fine but now i have to combine this with keypad.
Basically, its something like code lock with lcd.
This is the schematics:
4x4 keypad Pictures, 4x4 keypad Images, 4x4 keypad Photos, 4x4 keypad Videos - Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
and this is full program:
COLUMNS are on portC
ROWS are on portG
void ScanKeyMatrixInit();
char ScanKeyMatrix();
char keyPadMatrix[] =
    '1','2','3','A',
    '4','5','6','B',
    '7','8','9','C',
    '*','0','#','D',
    0xFF
    // reading the columns
    row1tris = 0;
    row2tris = 0;
    row3tris = 0;
    row4tris = 0;
    col1tris = 0;
    col2tris = 0;
    col3tris = 0;
    col4tris = 0;
    // This routine returns the first key found to be pressed during the scan.
	char key = 0,
	row;
    for( row = 0b00000001; row < 0b00010000; row <<= 1 )
       	{   // turn on row output
        row1port = (row & 0x0001)>>0;
        row2port = (row & 0x0002)>>1;
        row3port = (row & 0x0004)>>2;
        row4port = (row & 0x0008)>>3;
	        // read colums - break when key press detected
	        if( col1port ) break; key++;
	        if( col2port ) break; key++;
	        if( col3port ) break; key++;
		    row1port = 0;
		    row2port = 0;
		    row3port = 0;
		    row4port = 0;
    return keyPadMatrix[ key ];
//------------ debouncing -----------------
int checkKey( void)
	int i=0, r=0, j=0;
	int c;
// wait for a key pressed
	do{
	     delayms( 10);
	     if ((c = readKEY()))
	         if ( c>r)       // if more than one button pressed
	             r = c;
	         i++;
	     else
	         i=0;
	} while ( i<10);
// wait for key release
i =0;
do {
     delayms( 10);
     if ( (c = readKEY()))
         if (c>r)        // if more then one button pressed
             r = c;
         i=0;
         j++;            // detect long button hold
     else
         i++;
} while ( i<10);
if ( j>80)                  // longer than 500ms
     r+=0x80;
return r;
//	key = ScanKeyMatrix();
What do i need to add to make this program work ?
Thank you very much in advance !
i also have this project . please @CrEdo how did you go about with your project. pkease reply. im confused i dont know where to start from.
my project is electronic keypadlock with LCD and alarm.
the alarm is meant to ring when the wrong key sequecne is been pressed.
please house help me out !!!
Unfortunately i need to use the microchip C30 compiler to make this. Do not use this compiler!. It's much to complicated and totally useless in some parts of code development. Choose CCS instead. It's much better / faster / generated code is smaller.
To do this project goto CCS forum and use the search.
You will get bunch of data regarding LCD and Keypad.
C.E.
