4X4 keypad to pic
i need to display keypad value on uart. please chk embedded c code. i wrote the code but its not working correctly plz chk the code given below:
#define keyport PORTD //keypad connected to PORTD
#define col1 RD0 //column 1
#define col2 RD1 //column 2
#define col3 RD2 //column 3
#define col4 RD3 //column 4
#define TRUE 1 //some defines
#define FALSE 0
const unsigned char character_from_keypad[4][4]={
{'0','1','2','3'},
{'4','5','6','7'},
{'8','9','A','B'},
{'C','D','E','F'}
void key_init()
TRISD=0x0F; //make Rows as o/p and cols are i/p
keyport=0xFF;
unsigned char get_key()
unsigned char row,pressed_col,keypad_value=0;
for(row=0;row<4;row++) //loop for 4 rows
keyport &= ~(0x80>>row); //to make rows low 1 by 1
if(!col1) //check if col1 is pressed
while(!col1)
continue;
DelayMs(50); //wait for release
pressed_col= col1; //set key number
keypad_value=character_from_keypad[row][pressed_col];// to read the value from keypad
return keypad_value; //return key number
else if(!col2) //check if col2 is pressed
while(!col2)
continue;
pressed_col=col2; //set key number
else if(!col3) //check if col3 is pressed
while(!col3)
continue;
pressed_col=col3; //set key number
else if(!col4) //check if key4 is pressed
while(!col4)
continue;
pressed_col=col4; //set key number
else
//pressed_col+=4; //next row key number
keyport |= 0x80>>row; //make the row high again
return FALSE; //return false if no key pressed
void main()
unsigned char keypad_input;
init_comms();
key_init();
while(1)
keypad_input=get_key();
putch(keypad_input);
thanks
use the MM74C922N keypad encoder. its makes it so much easier, because by configuring the debounce and scan time periods you dont have to bother about them. all tht you hav to do is read the data from the IC...
