I have been modifying Nigel's 16F628A tutorials to run on the 16F1827. So far I haven't been able to configure them to run on the 4mhz internal clock. I would like to do that to use the LCD routines. Could someone help me with that? This runs okay with the 20mhz crystal but I would like to use the 4mhz internal clock.
Blinks 8 LEDs on PORTB in asm.
C:
;Modified from Tutorial 1.5 - Nigel Goodwin 2002 tutorials from Electrotech online
list p=16f1827 ; list directive to define processor
#include <p16f1827.inc> ; processor specific variable definitions
; CONFIGURATION WORD SETUP
; __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_ON & _IESO_OFF & _FCMEN_OFF
__CONFIG _CONFIG1, _FOSC_HS & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_ON & _IESO_OFF & _FCMEN_OFF
__CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
cblock 0x20 ;start of general purpose registers
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
endc
LEDPORT Equ PORTB ;set constant LEDPORT = 'PORTB'
LEDTRIS Equ TRISB ;set constant for TRIS register
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
; movlw 0x07
; movwf CMCON ;turn comparators off (make it like a 16F84)
; bsf STATUS, RP0 ;This doesn't work on 16F1827 use BANKSEL instead
BANKSEL TRISB
movlw b'00000000' ;set PortB all outputs
movwf LEDTRIS
; bcf STATUS, RP0 This doesn't work on 16F1827 use BANKSEL instead
BANKSEL PORTB
clrf LEDPORT ;set all outputs low
Loop
movlw b'10000000'
; movlw b'11111111'
movwf LEDPORT
call Delay ;this waits for a while!
movlw b'01000000'
movwf LEDPORT
movlw b'00100000'
movwf LEDPORT
movlw b'00010000'
movwf LEDPORT
movlw b'00001000'
movwf LEDPORT
movlw b'00000100'
movwf LEDPORT
movlw b'00000010'
movwf LEDPORT
movlw b'00000001'
movwf LEDPORT
goto Loop ;go back and do it again
Delay movlw d'250' ;d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
end
