433 MHz TX/RX
tom_pay
Hi
I would like to get a PIC, preferably a PIC16F684, and send a number ( 1 - 20 ) between it and another PIC, with a wireless transmitter.
I was going to use a 433MHz transmitter / receiver pair. Unfortunately it only has line of communication, in one direction.
Could someone please help me with this problem. I am very confused.
Tom
Hi
Unfortunately I can only buy the separate modules. In RX or TX only, not both. :-(
Does this make it more complicated?
Tom
Yes, you need a transmitter and a receiver at each end - and you will probably need to power them up and down as you use them.
Is two way communication essential?.
Two way communication is not essential.
The Tx only has to transmit and the Rx only has to receive.
Last thing, I have decided to change its range. 0 - 255 would better. Hope this doesn't make it harder.
Tom
Tom
Check my tutorials, which cover what you want. 0-255 would be the minimum regardless, a single byte.
Hi
Thanks for that,
I had already looked at your site, but couldn't find what I was looking for. But after a while I found it.
Thanks so much, your website is so helpful and easy to understand.
Tom
Hi
I have just had a play with MPLAB. I have decided to write my code in a way that requires different variables containing the individual bits of the number needed to be communicated.
Unfortunately the way that I have done it takes too much time.
"bit7 = (commdata >> 7 ) & 0b1;" ect.
Does anyone know a way to split them up quicker?
Tom
