roltex_rohit123
hi friends..
i am trying to study a MM74HC4046 and had a few doubts.
does it require any source frequency or it can itself provide pulses.
can the vco out and comparator in be directly connected or we need a frequency divider. if i want a frequency of 3.5 MHz can i directly connect the two pins if not which ic shall i use?
can we use zener diodes to regulate the voltage since i would be powering it from 12 v and ic needs just 4.5 volts in normal use?
if i am trying to use thes circuit for my desulfator can zener diode still be used?
pls friends guide me i'm in urgent need to make this circuit..
