Hello. I have to ask you for information if you want to help me. i have to buy 5 4 channel bench oscilloscopes which will probably be a rigol DS1054Z and 5 dual bench power supplies. the aim is to use an oscilloscope and a dual power supply for two separate circuits on two breadboards that a couple of guys will work on. I know that the masses of the channels of an oscilloscope are in common and therefore I have a doubt. if the electrical circuits to be analyzed are two and separate, a pair of channels works on one circuit and the other pair of channels works on the other circuit, therefore each pair must be independent. does it work that way?
