4 By 4 matrix key pad
GreenP
Hi There
Is there anyone out there who has some c code for the scanning of a 4* 4 matrix keypad?
greenP
Assumes layout 0123/4567/89ab/cdef, 048c in column 3 (bit value 8), cdef in row 3(bit val 8).
Also assumes the existence of a setcol function which will send a current up a column, and a getrow function that will check for a current coming back from a row.
NB: not tested
int num=0;
int col=8,c=0;
while (col)
 setcol(col);
 if (getrow(1)) num=c;
 else if (getrow(2)) num=4+c;
 else if (getrow(4)) num=8+c;
 else if (getrow(8)) num=12+c;
 col/=2;c++;
Depending on connection characteristics, allow some SETTLING time before reading the rows of the grounded columns. Also, reading them with analog inputs allows an adjustable threshold for noise rejection if necessary.
