This might not be a good place to post this but here goes.
On my quest for driving aircraft instrumements directly I found that on some it isnt practical to remove the synchro motor (and replacing it with a stepper or whatever), so driving one would be the only other solution.
Generating 3 phase controlled 120v sine waves for the stator and a phase related 120v sine wave for the rotor isnt that easy with a micro.
So I had an idea, run a synchro backwards, generate 3 fixed 120 degree phases, use a power op amp or audio amp to drive a standard mains transformer to generate the 3 phase 12ov and stick this on the stator windings, then apply just one modulated sine wave (generated in similar fashion) to the rotor, shifting the phase from 0 - 360 degrees with relation to phase 1 of the stator ought to give me the 0 to 360 degree rotation of the synchro shaft.
Generating 3 phases at 400hz with a dac is no hard task, and generating a fourth phase shifted output according to the required display variable shouldnt be that difficult.
Anyone with knowledge of this sort of thing?
