3.4V VF LEDs operated by 3.3V
EngIntoHW
The µC I'm using can source 20mA at 3.3V.
I'd like to use a bi-color green-blue LED (HSMF-C168) which each of its colors has a typical VF of 3.4V and maximal VF of 3.8V.
I'm aware that the LEDs will illuminate more weakly.
I'd like to know whether they will still illuminate.
Thanks.
Every LED from each manufacturer has a different characteristic. I have found that LEDs will illuminate weaker and weaker as the voltage drops below their "characteristic" voltage. Many will still illuminate when the voltage drops by as much as 0.5v.
The tiny LEDs are extremely dim. Ordinary LEDs are 1000 times brighter.
You don't know if your LEDs need 3.2V or 3.8V so it is a gamble to see if they will light with only 3.3V.
The output of the micro-c will be less than 3.3V when it has an output of 10mA.
The max current for the LEDs is only 10mA, not 20mA.
To me that seems to be a high foreward voltage compared to typical LEDs. I have some that have a foreward voltage of 1.8V. LEDs are cheap, and you should be able to find a foreward voltage lower than 3.3V.
Hello,
Some of the other color LED's (like white) have a much higher forward voltage, like as high as 3.5 volts. Those colors dont come much lower.
Consider pulsing the pin with a square wave and using an external voltage doubler to drive the higher forward voltage LED's.
