augustin87r
Hello,
I would like to build a 2 way passive crossover for a pair of 2 loudspeakers system made in USSR (TENTO) a few years ago. I don't have the original speakers, nor the crossover inside so i decided to build one. The speaker cabinet is very nice and i think it was well calculated.
I have two 4 ohm speakers inside:
YDD 200 LPP
DIAM=200mm D. Magnet=100mm Putere M=150W
Frequency=55HZ-5KHZ
Senz=90dB Imped=4ohm;
output 75W
and this one:
Untitled
As you have noticed, i don't have a tweeter but a midrange speaker. I really do not want to use a tweeter because i don't like high pitched sounds. Anyhow, this speaker will reproduce quite well higher sounds....
I'm wondering what filters should i use? 2nd order or 3rd order? I have read that there is not much difference between 2nd order and 3rd order. The big difference is between 1st order and 2nd order.
However, i read about 2nd order here :
Second Order Passive Crossovers, 12 dB per Octave
and about 3rd order here:
Third Order Passive Crossovers, 18 dB per Octave
Building the inductors is very easy, i just have to specify the inductance
Shavano Music Online - Cross-Over Network; Air Core Inductor Calculator
Calculating the right inductance is difficult for me. This calculator makes things very easy, all i have to do is specify the speakers impedance and the frequency.
Passive Crossovers, Capacitor and Coil Calculator
The problem is i don't know what to introduce in the frequency field. I would like to get the best from these speakers. A three way crossover would have been easier. I think the 2 way is difficult because it's a compromise. It uses 2 speakers for the whole range instead of 3 separate speakers like in a 3 way system.
Any suggestion is welcome...
YDD 200 LPP
Frequency=55HZ-5KHZ
output 75W
and this one:
Untitled
