2 PWM Dead-Band Control
skyflyer54
May I know is there anyone come across microchip PIC MCU which have 2 pwm dead band control?
Currently i'm using PIC18F4520, PICF4620, PICF4550 which all only have 1 pwm dead band control which is on Half-bridge output mode.
Please advise. Thanks.
I don't know if you're set on PICS but you may want to look into the tiny26 chips from Atmel. They have 2 high speed PWM outputs that do not overlap (Which is what I think you're looking for) They have other chip lines that have multiple PWM outputs with adjustable deadband that you may want to look into, though I can't recommend the exact parts off the top of my head. You may want to consider using a single MCU as a multi phase clock generator for slave MCUs that actually generate the PWMs. Many times using a couple of simpler chips and coordinating their clocks will give you the same results at less cost.
Thanks Sceadwian...
I need to use microchip PIC chip as i was only provided with microchip development kit. Anyway, thanks for your recommendation.
Still, you could use a second chip as a slave to the first. I'm going to hazzard a guess they have an I2C or SPI interface.
