1n4148 forward voltage vs current graph
gjpollitt
Looking at the datasheet with forward voltage of 1v there should be around 170ma
On my test circuit I have 10vdc supply limited to 200ma, series resistor of 470 ohms and then the 1n4148 diode.
My question is why am I only measuring 20mA ? I have a voltage of .95 across the diode which suggests I should be getting at least 100ma.
Graham
Small calculation:
(10V {psu voltage} - 0.95V {diode Vf} ) / 470 ohms = 0.0193A = 19.3mA.
Your series resistor is too high a resistance to allow 100mA from a 10V supply. Try reducing it to 82 ohms or so.
Maybe you expect the diode to generate 100mA? Then try it without your 10V supply. :lol: :lol:
I think you may be looking at it in a wrong way. The forward voltage drop is specified with a average current. This voltage drop can vary with temperature. In fact the older version of the 1N4148 the 1N914 has been used as a temperature sensor on occasion by monitoring the forward voltage with a specified current flowing thru it. I also remember seeing a circuit or two that used the forward voltage of this type of diode as a voltage reference source.
