18f4550 mikroC usb 20Mhz config settings.
Those config settings will set the 18F4550 up using a 20MHz crystal, running the CPU at 48MHz (12MIPS).
I answered that way because I was unsure if you wanted the CPU to run at 20MHz or you want to use a 20MHz crystal.
ye,
i want to run the HID example with this configuration,
But i when i connect the PIC burnt with this config, the device manager says, USB device cannot be started.....
