16ff877 dificullty
echo_bry
hi there! is there some1 here who can help me with my problem with my 877 pic. my pic wasnt able to give me the correct output of high logic eventhough i had my PORTC and A in all bit set. what could be the problem with that?thanks
:( [/b]
Nigel Goodwin
Super Moderator
Most Helpful Member
:( [/b]
Make sure you disable the A2D inputs, these are enabled by default and make ports A and E inputs. The 877A also has comparators (but I don't know which port they use), these are possibly also enabled by default.
Failing that, post the code so we can look!.
echo_bry
thanks
hey there thanks for the help...really appreciate it, can i send my code later to you? and another thing, have you heard of the MAXIM 114 an ADC chip(8bits)...coz im trying to interfaced it with my pic using its outputs as my input for my pic..PORTB will be my input from ADC!
ivancho
No need to use an external ADC, there is a built in ADC 8bit (or 10 bit) in the 16F877... you just need to apply your analog volatage straight to the PIC and set ADCON registers, and tell it to do the conversion.
It is easly done... and you don't waste I/O, and time comunicating to a ADC converter.
Ivancho
echo_bry
adc difficulty
hi there ivancho, nweiz thanks for the reply.... the reason why we used an external ADC is that i dont know how to make use of the ADC in the PIC and it will cost us much time..can you show me an example of it?
:D
Nigel Goodwin
Super Moderator
Most Helpful Member
Re: adc difficulty
:D
It's really easy, far easier than using an external one - full details are in the datasheet.
This code section reads the A2D and saves the 10 bit result in Var2 and Var2+1.
; Start(ADC)
    BSF      ADCON0, ADON
    BSF      ADCON0, GO_DONE
    BTFSC    ADCON0, GO_DONE
    GOTO     $-1
; A=ADC_Result
    MOVF     ADRESH,W
    ANDLW    0x03
    MOVWF    Acc1H
    BANKSEL  ADRESL
    MOVF     ADRESL,W
    BANKSEL  ADRESH
    MOVWF    VAR2
    MOVF     Acc1H, W
    MOVWF    VAR2+1
You also need to set it up first, but again, it's all explained in the datasheet.
echo_bry
adc
wut if i need to compare my inputs by subtracting them : new - previous, then ill check its carry if it is 1 or 0.....can it comprehend with the speed of my sensor which will have its output in just 5 seconds?
Nigel Goodwin
Super Moderator
Most Helpful Member
Re: adc
Yes, no problem - a 16 bit subtraction can be done pretty fast, using a 20MHz crystal a 16F877 can perform 5 instructions in 1uS, that's 5,000,000 instructions per second.
Depending on the resolution you need, and how you set the A2D up, you can use it as an 8 bit A2D, this way you only need to do an 8 bit compare.
But if you're talking about 5 seconds - that's an absolute age in PIC terms, most PIC's spend the vast majority of their life in loops wasting time!.
echo_bry
code for our thesis
sir my problem is how can i give my source code an overhaul by not not using the whole PORTBas my input and use only one pin from PORTE as my input...CAN YOU HELP ME WITH MY ADC IN THE PIC?thank you very much sir :D
Nigel Goodwin
Super Moderator
Most Helpful Member
Re: code for our thesis
I don't really understand the question?.
For an analogue input, it only uses one input pin - you can select which one it uses by writing to a register. The 16F877 only has one A2D, this is switched to the different input pins by the value in the register.
What are you actually wanting to do?.
motion
Which ones are digital inputs and which ones are used as ADC inputs?
EE World Online Articles
Loading
