16f877a Eeprom Data Corruption
andyy07
Hi.
I have a little problem with eeprom on a 16F877A. When I turn the power on and off and then back on a few tmes the eeprom data is corrupting. When I read it back I find that it's really messed up.
Do someone have a solution for this ?
Thanks in advance.
Bad eeprom write code.
Post your entire code.
Could be bad reading code as well. Have you tried replacing the suspect IC with a couple of others? Have you been succesful with the EEPROM using this same code before?
I don't think is the code...I filled all the eeprom with 0s in ICPROG an I turned the power on and off a few times without writing or reading it with my code and it got messed up....anyway here's the code of read and write:
; EEPROM READ
ee_read
movf ee_adr,W
bsf STATUS, RP1
bcf STATUS, RP0
movwf EEADR
bsf STATUS, RP0
bcf EECON1, EEPGD
bsf EECON1,RD
bcf STATUS,RP0
movf EEDATA,W
bcf STATUS, RP1
bcf STATUS, RP0
movwf read_result
return
; EEPROM WRITE
ee_write
bsf STATUS, RP1
bsf STATUS, RP0
btfsc EECON1, WR
goto $-1
bcf STATUS, RP1
bcf STATUS, RP0
movf ee_adr,W
bsf STATUS, RP1
movwf EEADR
bcf STATUS, RP1
bcf STATUS, RP0
movf write_data,W
bsf STATUS, RP1
movwf EEDATA
bsf STATUS, RP0
bcf EECON1, EEPGD
bsf EECON1, WREN
movlw 0x55
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1, WR
bcf EECON1, WREN
bcf STATUS, RP1
bcf STATUS, RP0
btfss PIR2,EEIF
goto $-1
bcf PIR2, EEIF
return
This sounds more like ICPROG being inconsistent when reading the EEPROM. If you simply read the EEPROM a few times, do you get consistent results? Have you tried different software such as WinPic (available from this page.).
It sees like I've resolved the thing, I've activated PWRT an the bad thing did not happen no more...anyway I got to make more tests to be sure....I don't think ICPROG has problems but who knows....
I suggest adding BCF INTCON, GIE at the top of your ee_write routine. This will prevent interrupts from interfering.
It is easy to tell if the problem is the harware or software.
Blank the FLASH.
If the EEPROM gets corrupted with blanked flash then it is a hardware problem because there is no code.
