16F877A data sheet query
sae140
I understand that the 16F877A device has a 20Mhz spec, and that the 16LF877A has a 10Mhz spec.
However, on page 231 of the data sheet, example c) reads: PIC16F877A-I/P = Industrial temp., PDIP package
10 MHz, normal VDD limits.
Can anyone au fait with this device kindly explain where the 10 Mhz comes from in this example ? Ta.
Rest assured 16f877A-i/p runs at 20Mhz. I have used it at that. Sorry if this wan't your worry.
it is correct.
if you use FF877, it works only up to 4MHz with a supply between 2 to 3V.
from above 3V to 5V , it reaches 10MHz and that is the Maximum.
the F877A starts working at 4V onwards to 5V but can work at 20MHz
it is correct.
Mmmm. How is example c) correct then ? The example c) on page 231 refers to the 'F877A, not the LF version.
From the device marking PIC16F877A-I/P, they (Microchip) have somehow determined that this is a 10Mhz part.
The example given does not match device spec information elsewhere in the data sheet.
thecritic - Rest assured 16f877A-i/p runs at 20Mhz. I have used it at that. Sorry if this wan't your worry.
Appreciate your reply - not so much 'worry', but the device data sheet is now 7 years old, and you'd have thought that any typo's (assumption) would have been corrected by now ...
i don't see page 321 on my datasheet i had
Hello Sarma - it's page 231 - if you need it, the download link is: https://www.electro-tech-online.com/custompdfs/2011/02/39582b.pdf
There are also a couple of Errata sheets on Microchips's site - one of which (B7) I hadn't downloaded (whoops !): https://www.electro-tech-online.com/custompdfs/2011/02/80276A.pdf
which confirms that it's a typo ... should have read 20Mhz.
Can sleep easy now - thanks for all the input.
