I am trying to complete a project that lights an led on one second and then off for one second and on the fifth second lights a separate led. I am using a PIC16F690 and the code line "btfss STATUS,2" apparently never goes to 0 because the program never skips the next instruction. Please help.
list p=16F690 ; list directive to define processor
#include <p16F690.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CP_OFF & _CPD_OFF & _BOR_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _FCMEN_OFF & _IESO_OFF
;declarations
INT_VAR UDATA_SHR
Marker125 res 1
Post125 res 1
fivSEC res 1
RESET_VECTOR CODE 0x0000 ; processor reset vector
goto start ; go to beginning of program
INT_VECTOR CODE 0x0004 ; interrupt vector location
Init
;initialize PORTA example 4-1 in datasheet
BCF STATUS,RP1
CLRF PORTA
BSF STATUS,RP1
CLRF ANSEL
BSF STATUS,RP0
BCF STATUS,RP1
MOVLW 0Ch ;set RA<5:4,1:0>;as outputs
MOVWF TRISA
BCF STATUS,RP0
;8 Mhz internal timer oscillates 2,000,000 times a second
;2,000,000/256(prescaler)=15,625 cycles to 1 second after prescaler
;125(Marker)x125(Post)=15,625
movlw b'00000000' ;disable TMR0 interrupt
movwf INTCON
movlw b'00000110' ;internal instruction cycle,prescaler assigned to TMR0
movwf OPTION_REG ;Prescaler 1:128 for even numbers on "Mark125" and "Post125"
movlw d'125' ;move decimal 125 in GPF called Marker125
movwf Marker125
movlw d'125' ;move decimal 125 in GPF called Post125
movwf Post125
movlw d'5' ;move decimal 5 in GPF called fivSEC
movwf fivSEC
TimeLoop
movfw Marker125 ;move number from Marker125 into working register
subwf TMR0,0 ;As TMR0 counts up, the decimal in Marker125 will
;subtract and store the number in the w register
;this leaves the number in TMR0 unchanged
btfss STATUS,2 ;When the above number reaches 0 the next
;instructions will be skipped
goto TimeLoop ;loop until Marker125 - TMR0 = 0
movlw d'125' ;add 125 to Marker125 and store in Marker125
addwf Marker125,1
decfsz Post125,1 ;Decrement the postscaler and store in Post125
goto TimeLoop ;this line is skipped once Post125 = 0
;when the Timeloop reaches this point 1 second has passed
movlw d'125' ;add 125 to Post125 and store in Post125
movwf Post125
retlw 0
MAIN_PROG CODE
start
call Init
Main
decfsz fivSEC,1 ;decrements fivSEZ by 1 and stores contents in fivSEC
;register
goto toggle ; skips of 0
bsf PORTA,4 ;sets high bit 4 of PORTA once fivSEC reaches 0
movlw d'5' ;move number 5 into fivSEC register
movwf fivSEC
goto TimeLoop ;repeat timeloop
toggle
bcf PORTA,4 ;turn bit 4 off
movlw b'100000' ;toggles RA5 and stores contents in w register
xorwf PORTA,0
END ; directive 'end of program'
;declarations
INT_VAR UDATA_SHR
Marker125 res 1
Post125 res 1
fivSEC res 1
Init
BCF STATUS,RP1
CLRF PORTA
BSF STATUS,RP1
CLRF ANSEL
BSF STATUS,RP0
BCF STATUS,RP1
MOVWF TRISA
BCF STATUS,RP0
movwf INTCON
movwf Marker125
movwf Post125
movwf fivSEC
TimeLoop
addwf Marker125,1
movwf Post125
retlw 0
MAIN_PROG CODE
start
call Init
Main
;register
movwf fivSEC
toggle
xorwf PORTA,0
