16 Bit Subraction
Suraj143
Active Member
I have a 16bit subtract code. Can I tell one of the values greater or less than by looking at the CARRY bit?
I dont need the result I need to know what value is bigger or less.
Num_L,Num_H	=value to be subtracted
NumF_L,NumF_H	=fix value
[Num_H] [Num_L]= [Num_H] [Num_L] - [NumF_H] [NumF_L]
Sub16	movf	NumF_L,W
	subwf	Num_L,F
	movf	NumF_H,W
	btfss	STATUS,C
	addlw	.1
	subwf	Num_H,F
	btfss	STATUS,C
	;if carry set [Num_H] [Num_L] bigger
	;if carry not set [NumF_H] [NumF_L] bigger
when I don't need to know the result I use,
		movfw	Num1H		;compare high bytes
		subwf	Num2H,W
		btfss	STATUS,Z	;if same compare low bytes
		goto	GotResult
		movfw	Num1L
		subwf	Num2L,W
GotResult
;carry Set if Num1<=Num2
		subwf	Num2H,W
		goto	GotResult
		movfw	Num1L
		subwf	Num2L,W
GotResult
Thats exactly what I need thanks for that.
