AirControl
I retrofitted my truck with hid projector lights that are controlled off aftermarket relay harnesses. Those relays are activated by the oem signal that used to plug into the halogen bulbs. When I turn on my high beams it cuts power to my fog lights. I would like to have my fog lights come on when I turn on my high beams. I would like to run a wire from the high beam signal to the relay coil of the fog lights and put in a diode in series. That way only the high beams activate the fog lights and the fog lights can't turn on my high beams. However, I am unfamiliar with diodes and am unsure which to use. Can anyone help me select a diode for this?
Also, I had a shop install a security alarm in my truck after someone broke into it. However, they tied a relay coil into my interior dome lights (not sure what it actually controls) and every time my inter lights dim the relay chatters like crazy. How can I stop this?
Any help would be greatly appreciated, thanks
