12F683 boostc configuration help
RobertTrue
Hi I'm new to pic programming but not new to C programming,
Can someone help me configure a 12F683 in boostC I just want to be able to use the gpio register to blink leds on the 5 output pins. I have read most of the datasheet and the newcomers sticky and I still cant figure it out.
Here is the code so far.
#include <system.h>
#include <PIC12F683.h>
#pragma DATA _CONFIG, _WDT_OFF & _INTOSCIO
#pragma CLOCK_FREQ 4000000
char count = 00000000b;
char GPP0 = 00000001b;
char GPP1 = 00000010b;
char GPP2 = 00000100b;
char GPP4 = 00010000b;
char GPP5 = 00100000b;
void main()
 osccon      = 01100001b;
 cmcon0      = 7;    //set digital IO
 adcon0      = 0 ;
 ansel       = 00000000b;
 wpu         = 0;
 trisio      = 00001000b;    //set input , output
 gpio        = 00000000b;
while(1)
    set_bit(gpio,GPP0);
    set_bit(gpio,GPP1);
    set_bit(gpio,GPP2);
    set_bit(gpio,GPP4);
    set_bit(gpio,GPP5);
    delay_ms(1000);
    clear_bit(gpio,GPP0);
    clear_bit(gpio,GPP1);
    clear_bit(gpio,GPP2);
    clear_bit(gpio,GPP4);
    clear_bit(gpio,GPP5);
    delay_ms(1000);
Any ideas as to what I'm doing wrong?
Can someone post the configuration that they would use?
Its doesn't have to be in C
Try changing:
to
char GPP0 = 0;
char GPP1 = 1;
char GPP2 = 2;
char GPP4 = 4;
char GPP5 = 5;
The set_bit and clear_bit functions (bsf and bcf in assembly) take the bit number (0-7) as a parameter, not a bit mask.
You could also set all the GPIO bits for your LEDs with a single command: gpio = 00110111b;
and clear them with gpio = 0;
Try changing:
to
char GPP0 = 0;
char GPP1 = 1;
char GPP2 = 2;
char GPP4 = 4;
char GPP5 = 5;
That was the problem it works now TYVM.:)
