andrew2022 said:**broken link removed**
NOTE: i tried this last night, and the capacitor exploded, so be warnedyou may need to change a few things
andrew2022 said:i did put the caps the right way round... it still blew for some reason... and what would you say was a better inverter schematic?
Nigel Goodwin said:If you put them the way shown in the diagram, that's the wrong way.
andrew2022 said:Nigel Goodwin said:If you put them the way shown in the diagram, that's the wrong way.
am confused. from lookin at the diagram i thought they were in the right way?
J0HN1 said:Hi mhutsby, Hi andrew,
This inverter circuit has cropped up a good few times.
Every time i see it, i cringe.
I too thought the capacitors were the wrong way round,
but this is not the opinion of others who have examined
this circuit.
J0HN1 said:Hi Nigel,
Please have a look through that earlier thread about
the same circuit, and the thoughts of others who have
looked at it.
That earlier thread has a colourful diagram with all the
component values included.
This poster did not mention that he was using 3055's
but you are correct, those are the ones that this is
supposed to use.
https://www.electro-tech-online.com/threads/ip-core.2695/
I would be very interested in your comments on what
others have said about it.
J0HN1 said:yes that is me too, i was away at another machine, and got
no cookie. I couldn't remember my password, so i just registered
again. Later realised i could have asked for my password !
andrew2022 said:to make the inverter more powerful can 2 3055 transistors be connected in parallel
Nigel Goodwin said:andrew2022 said:to make the inverter more powerful can 2 3055 transistors be connected in parallel
You can parallel bipolar transistors, as long as you fit seperate resistors in the emitter lead of each one, to ensure the current is divided evenly - generally you would use very low values, depending on the current handling required.
In this case though, the circuit would be even less likely to work!.
andrew2022 said:Nigel Goodwin said:not a good thing... plan B is to get an old UPS... ideally i need an inverter what can handle 900W min
Maplin sell a 600W inverter for £80, which sounds pretty reasonable, but bear in mind 600W is 50A at 12V, assuming 100% efficiency!. They do either 12V or 24V versions, which would obviously half the current at 24V.
So a 900W 12V inverter would require upwards of 75A.
Do you have a specific use in mind?.
