106 B or C SCR rating?
All i know is thats what I was told use use in place of the neon in my bass pedal triggered strobe circuit project.
circuit seen here
https://www.aaroncake.net/circuits/strobe.htm
neon is L1
im not sure where to get this scr... I have plugged it into all my electronic sites for ordering parts and nothing came up.
the goal is to use a piezo trigger to trigger an SCR which will close the contact of the neon making the strobe trigger once every hit.
well if i cant find this 106B or C SCR than what else is there to use?
and if this SCR only has 3 leads how to i wire it between the 2 leads of the piezo and the 2 leads of the neon spot?
A 400 volt, 100mA SCR (to-92 case) should work, if an SCR is the right device to use. How much voltage comes out of the piezo trigger? If it is the type used to ignite propane stoves, it will blow up the SCR.
Look for C106B , it's a older part, but still made by many. I think it was originally made by GE or maybe Motorola. It's a garden variety SCR, 4 amp, 200 V part, in the "B" designation. Used in light dimmers, etc. There are lots of package and lead variations, identified by numers after the "B", so check the datasheet of whoevers version you get.
Here is another circuit, with remote operation via optoisolator. May be more suitable to your planned use. It comes with an explanation of how it works, and how to build etc.
the trigger piezo is from allelectronics.com item PE-35
i have no idea what voltage it makes...i should get the tester on it
looking at jameco.com i turned up this scr
https://www.jameco.com/webapp/wcs/s...storeId=10001&catalogId=10001&productId=14736
it should work, right?
I got my SCRs in with the order for the power supply
They didn't have the C106B but they did have a few C106BC SCRS rated at 200V and 4A. Here's the data sheet:
These SCRs have 3 leads, the Trigger has 2 leads, and the Neon on the strobe circuit has two leads.
How would I wire the SCR to trigger in place of the neon?
I was thinking something like this.
I normally don't work with SCRs though so I could be totally off on that one
One wire is the input from the piezo. Another wire is the output to the SCR and the 3rd wire is common to both input and output.
