Continuing with my loarn experiments I built a 100khz receiver to pick up loran pulses.
I get a lot of 100hz hum, if I power the circuit from my bench psu I hear loran with a load of 100hz messing up th esignal, if I pull the - or + power connection the circuit slowly dies with the supply cap discharging, still hum, but if I pull both supply conns the hums goes away, and recption decreases but is still there.
So i assume the rx is using the mains wiring as the ant, capacitively coupling through transformers, and 100khz is a decade multiple of 100 hz, hence the hum, other low freqs like 60khz work ok.
So how do I keep rf away from the power rails?
