    Dismiss Notice
Zilog comparator programming for battery and supercap
Discussion in 'Microcontrollers' started by kct, Apr 14, 2010.
  1. kct
    kct New Member
    Apr 14, 2010
    1
    0
    Good day to everyone.
    Currently I'm in the process of using a Zilog MCU (Z8F042A) to design a voltage comparator for comparing a voltage between a mobile phone battery with a maximum voltage of 4.2V, and a supercapacitor(s) rated at 5V. At any instant the supercapacitor's voltage is equivalent to that of the battery, the system will send a voltage to the gate of a P channel MOSFET to switch the MOSFET off. The moment the supercapacitor's voltage falls below that of the battery, the MOSFET is to be switched on again.
    The problem now is, I am not so sure about programming the Zilog itself (programming has never been my strong point), not to mention the issue of whether I need to use the ADC or not. It would be great if anyone can help me out.
    This is what I have so far...
    Code (text):
    #include<eZ8.h>
    #include <stdio.h>
    #include <sio.h>
    #include <adc.h>
    unsigned int VINSUP; // Voltage from Supercapacitor
    unsigned int VINREF; // Voltage from Battery
    void main(void)
       ADCCTL0 = 0xAE; // Conversion Enabled
                   // Reference Buffer Disabled
                   // Continuous Mode
       ADCCTL1 = 0x01; //Single Ended Buffered Input with Unity Gain
       PCDD = 0xF7; // PC3 as output and others as input
       PCOUT = 0xFF; // Turn off all ports
       while(1)
          if ((PCIN & 0x01) == 0) // To check if PC0 is low or not
             PCOUT = 0xF7;
          else
             PCOUT = 0xFF;
  2. DirtyLude
    DirtyLude Well-Known Member
    Aug 5, 2003
    1,904
    56
    Toronto, Canada
    You really have just the basics there. Your best bet is to check out the yahoo groups mailing list. There's sample code in the files section and people who know what they are doing. I could help with the ADC, but I've never used the comparator before.
    z8encore : Z8 Encore! and ZNEO MCUs from Zilog
Share This Page
