    Dismiss Notice
Zener diode?
Discussion in 'General Electronics Chat' started by simon1979, Nov 22, 2016.
  1. simon1979
    simon1979 New Member
    Nov 22, 2016
    12
    0
    Hi all, I'm new here and would like some help. I have a PCB board off an appliance. I've noticed a zener diode(?) Is damaged. Does anyone know what value or number it could be? Hope the pic is clear enough. The damaged one is on the right Thank u. IMG_20161122_195909_230.JPG IMG_20161120_205155_785.JPG IMG_20161120_205155_785.JPG IMG_20161122_195909_230.JPG
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    Zener diodes usually have their voltage printed on the casing, so a blurred picture without any writing on it offers no clues.
    A picture of the entire board might offer some clues?, as would knowing what the zener actually does?.
  3. simon1979
    Nov 22, 2016
    12
    0
    I can't see a single thing printed on them . I can put a whole pic up of the board. A new PCB from aga/Rayburn is nearly £700!
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. simon1979
    Nov 22, 2016
    12
    0
  6. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    Why such blurry photos? It's not that difficult to hold a camera still. Set it on something if you have to, but the pictures you are providing are not helping at all.
  7. simon1979
    Nov 22, 2016
    12
    0
    Ok taken some more pics will upload
  8. simon1979
    Nov 22, 2016
    12
    0
  9. simon1979
    Nov 22, 2016
    12
    0
  10. simon1979
    Nov 22, 2016
    12
    0
    All diodes are is copper colour and a single black band around the centre.
  11. cowboybob
    cowboybob Well-Known Member Most Helpful Member
    Oct 22, 2011
    3,026
    477
    James Island, SC
    Welcome to ETO, simon1979!
    Tough PCB to find, but:
    upload_2016-11-22_17-40-18.png Source: https://www.aga-spares.co.uk/index...._id=1315&virtuemart_category_id=76&Itemid=495. A Rayburn "Sequence Controller".
    No schematic that I could find.
    But from your pix, the diodes have been, obviously, carrying quite a lot of current. But few traces. Maybe zeners in series?
    Could you get a good, focused pic of the underside of that section of the PCB to help us see how they're wired?
    As for replacing them, and if they're zeners, I suspect that they're all the same value/type. What value may be tough to determine.
    <EDIT> Also, see this: (400G/L PX (PF): http://www.rayburn-web.co.uk/Prodin...urn 400GL PF instal 08-13 EINS 512531 (2).pdf - page 18.
  12. pfofit
    pfofit Member
    Nov 13, 2006
    129
    17
    Eastern Canada
    Howdy.
    What makes you think they are Zeners. Elsewhere on the board, red circle, there is a zener clearly marked as zd1.
    They're not always labeled zd but if there is one marked zd then i would hope any others as labelled the same.
    Also what is all that stuff everywhere, it might be conductive ? Is it just dust? Looks like corrosion or carbon.
    What environment is it in? Either way needs to be cleaned up
    Cheers
  13. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,918
    1,098
    ZD is likely a Zener diode. D9 is likely a 1N4148 which is a common switching diode.
    • Agree Agree x 1
  14. JLNY
    JLNY Active Member
    Mar 5, 2011
    220
    35
    New York, USA
    Maybe I'm completely wrong on this, but I'm not sure I can see any polarity markings on D4 or D6? Are we sure they aren't surge protection diodes of some kind?
  15. cowboybob
    Oct 22, 2011
    3,026
    477
    James Island, SC
    Could be. Odd that they're stuck off all alone the way they are.
    And the heat signatures around them certainly indicate a lot of heat.
    Good catch, pfofit.
    So, anyway, could use a pic of the underside for the traces. Might at least show how they're wired. Need a really close look at the the "diodes", whatever they are.
  16. DerStrom8
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    What are the wires coming out from beneath the diodes? What do they go to?
    I expect these diodes are, indeed, some sort of protection diode, be it TVS (transient voltage suppressor) or even just flyback to protect against voltage spikes when an inductive load switches off.
    That whole board needs a good cleaning. Get some isopropyl alcohol and a stiff-bristled toothbrush to clean it off.
  17. simon1979
    Nov 22, 2016
    12
    0
    Yes will give a good clean. Tha nks for all the replies! I'm beginning to think I've rub markings off the diodes! And they are diodes not zener diodes! Will get a pic up later of underneath the board. I'm think the other diodes away from the area in question are the same type. They have 3 bands on them.
  18. KeepItSimpleStupid
    Oct 30, 2010
    9,918
    1,098
  19. Scott Marshall
    Scott Marshall New Member
    Nov 23, 2016
    3
    0
    Have you actually tested them? They may be OK, just dirty.
    I'm familiar with Rayburn (er) systems, and they are usually oil or gas industrial heat exchanger burners. (I spent a few years in a potato chip plant as plant engineer, and subsequently have run an industrial controls business)
    The oil burners especially produce so much "gunk" it's often attracted by electrostatic charge and will occasionally make components look burned when they are in fact, only dirty. The pattern around the diodes looks like this effect.
    I've seen a pair of series diodes used as a flame out indicator before as well, and wonder if that may be the case here. (they react rapidly to temperature changes). Does that board tab face the burner thru an opening in the burner box? If so that may be the function of the diodes. Rayburner always held onto old tech way past it's prime, as the diode flame detector was a very 1940-50s kind of technology. Then again I could be totally wrong with that assumption...
    Hope I helped a little...
    Scott
  20. simon1979
    Nov 22, 2016
    12
    0
    IMG_20161123_190958_190.JPG diodes in another place on board
  21. simon1979
    Nov 22, 2016
    12
    0
    Underside of board
Share This Page
