    Dismiss Notice
Zener Diode
Discussion in 'General Electronics Chat' started by john_p_92505, Aug 28, 2010.
  1. john_p_92505
    john_p_92505 New Member
    Aug 28, 2010
    3
    0
    Can Zener diodes be placed in series to increase the zener voltage.
    That is, will two 10 volt zeners in series function identically to a single 20 volt zener?
  2. kinarfi
    kinarfi Well-Known Member
    Jul 7, 2009
    1,504
    30
    P. G., Utah, United States of America
    Haven't tried it yet, but I would say yes
    Kinarfi
  3. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Should function close enough for most purposes.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. tvtech
    tvtech Well-Known Member Most Helpful Member
    Mar 27, 2010
    3,166
    348
    South Africa
    No problem. Zeners connected in series are good to go.
    Add all the Zeners breakdown voltages together. There you have your end result and your final Zener Voltage.
    Something to remember: Don't mix 400Mw and 1W Zeners in the same series circuit.....the 400Mw are going to go faulty way before the 1W Zeners.
    Do the stufff/maths and check what is needed for your application.
    Cheers
  6. tvtech
    Mar 27, 2010
    3,166
    348
    South Africa
    I could not help this. The answer is YES.
    Cheers
  7. mbarazeen
    mbarazeen Member
    Aug 2, 2006
    745
    7
    saudi arabia, srilanka
    Not true always, its depends on the BD voltage of the diode, ex: you can connect a 10V (100mA)(=1W) diode in series with 5V (100mA) (=0.5W) without any problem.
    in another word, if you connect a 10V (1W) zener in series with 3V(500mW) zener, 1W one will fail 1st, not the 500mW one.
    never connect zeners in parellel, in series no problem. some times you can series rectifier diodes too in forword position to add 0.7V etc. to a zener.
  8. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,593
    477
    L.A., USA Zulu -8
    ONLINE
    The main differences of using them in series versus one higher voltage unit will be a difference in the knee impedance and likely a difference in the temperature coefficient of breakdown voltage.
Share This Page
