    Dismiss Notice
Yamaha keyboard does not power up
Discussion in 'Repairing Electronics' started by stoocats, Apr 22, 2010.
  1. stoocats
    stoocats New Member
    Apr 22, 2010
    2
    0
    Canada
    Neither adaptor nor batteries will power up my keyboard. I suspect a TO-220 package 3 lead transistor.its labeled BI342 but cannot find this anywhere.Any ideas where to troubleshoot?
    tks
  2. HiTech
    HiTech Well-Known Member
    Jun 28, 2006
    2,874
    30
    Penna. USA
    It's probably a 2SB1342 bot a BI342 often the prefix is ommitted and that I is likely a 1. The 2SB1342 is a TO-220 pkg. and it's specs are here:
    2SB1342 Datasheet
    What makes you think it's the culprit? Is it obvious by looking at it?
  3. stoocats
    stoocats New Member
    Apr 22, 2010
    2
    0
    Canada
    The power supply is a 12V adapter... the circuit board where the power enters, has several caps, resistors, and this transistor together with a smaller one. When I hold the power button on for a while this transistor warms up. The only thing that happens is a barely audible thump through the speakers. The LCD on the keyboard doesn`t get any juice.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. HiTech
    Jun 28, 2006
    2,874
    30
    Penna. USA
    is the LCD display backlit? or is it completely out without even segments? can you measure voltage on other board locations that may have marked voltages on it? If so the power supply isn't the issue. Often board connectors will be labeled as to each pin's function. Look for 12 volts and or 5 volts dc. for starters.
Share This Page
