fouadalnoor
Hello,
I am currently using the Atmel SAM4L Xplained board in order to write to a simple 16 character LCD display module (DEM 16217 SYH-LY). Unfortunately, I can't get any characters to display on the board. I suspect my programming (using C in Atmel Studio 6.1) might be wrong (I have double checked all the connections). I only have the display showing one line with 16 black rectangles, but no letters. According to the data sheet, the LCD initializes automatically on power up and gives an example of how to write to the display [www.display-elektronik.de/DEM16217SYH-LY.PDF] and [], but as I follow the example I can't get any letters to display. I also tried initializing it by instruction, but to no avail. I hope you can take a look at my main.c file and see if there are any obvious errors that I am making (I only need to functions so the code is not too complex).
Thanks in advance!
Below is my main.c file code
Thanks in advance!
* \file
* \brief Empty user application template
* \mainpage User Application template doxygen documentation
* \par Empty user application template
* This is a bare minimum user application template.
* For documentation of the board, go \ref group_common_boards "here" for a link
* to the board-specific documentation.
* \par Content
* -# Include the ASF header files (through asf.h)
* -# Minimal main function that starts with a call to board_init()
* -# Basic usage of on-board LED and button
* -# "Insert application code here" comment
* Include header files for all drivers that have been imported from
* Atmel Software Framework (ASF).
#include <asf.h>
void initIO(void)
//Setting the pins for: RS, R/W and E as outputs.
ioport_set_pin_dir(EXT3_PIN_15, IOPORT_DIR_OUTPUT); //RS
ioport_set_pin_dir(EXT4_PIN_5, IOPORT_DIR_OUTPUT); //R/W
ioport_set_pin_dir(EXT4_PIN_6, IOPORT_DIR_OUTPUT); //E
//Setting the pins for: Data DB0-DB7
ioport_set_pin_dir(EXT1_PIN_5, IOPORT_DIR_OUTPUT); //DB0
ioport_set_pin_dir(EXT1_PIN_6, IOPORT_DIR_OUTPUT); //DB1
ioport_set_pin_dir(EXT2_PIN_5, IOPORT_DIR_OUTPUT); //DB2
ioport_set_pin_dir(EXT2_PIN_6, IOPORT_DIR_OUTPUT); //DB3
ioport_set_pin_dir(EXT2_PIN_10, IOPORT_DIR_OUTPUT); //DB4
ioport_set_pin_dir(EXT3_PIN_5, IOPORT_DIR_OUTPUT); //DB5
ioport_set_pin_dir(EXT3_PIN_6, IOPORT_DIR_OUTPUT); //DB6
ioport_set_pin_dir(EXT3_PIN_10, IOPORT_DIR_OUTPUT); //DB7 <- Will need to change this to input later on (to check for busy signal).
void EightbitInit(void)
//8-bit interface mode.
//Function Set
ioport_set_pin_level(EXT3_PIN_15, 0); //RS = 0
ioport_set_pin_level(EXT4_PIN_5, 0); //R/W = 0
ioport_set_pin_level(EXT3_PIN_10,0); //DB7 = 0
ioport_set_pin_level(EXT3_PIN_6,0); //DB6 = 0
ioport_set_pin_level(EXT3_PIN_5,1); //DB5 = 1
ioport_set_pin_level(EXT2_PIN_10,1); //DB4 = 1
ioport_set_pin_level(EXT2_PIN_6,1); //DB3 = N = 1, N = Numbers of display line (N:2-line/1-line)
ioport_set_pin_level(EXT2_PIN_5,1); //DB2 = F = 1, F = Display font type (F:5*10 dots/5*7 dots)
ioport_set_pin_level(EXT1_PIN_6,0); //DB1 = 0 (don't care)
ioport_set_pin_level(EXT1_PIN_5,0); //DB0 = 0 (don't care)
delay_us(50); //wait more than 39us
//Display ON/OFF Control
ioport_set_pin_level(EXT3_PIN_15,0); //RS = 0
ioport_set_pin_level(EXT4_PIN_5,0); //R/W = 0
ioport_set_pin_level(EXT3_PIN_5,0); //DB5 = 0
ioport_set_pin_level(EXT2_PIN_10,0); //DB4 = 0
ioport_set_pin_level(EXT2_PIN_6,1); //DB3 = 1
ioport_set_pin_level(EXT2_PIN_5,1); //DB2 = D = 1, D = Set Display (ON)
ioport_set_pin_level(EXT1_PIN_6,1); //DB1 = C = 1, C = cursor on
ioport_set_pin_level(EXT1_PIN_5,1); //DB0 = B = 1, Blinking cursor (ON/OFF)- on.
//Display clear
ioport_set_pin_level(EXT2_PIN_6,0); //DB3 = 0
ioport_set_pin_level(EXT2_PIN_5,0); //DB2 = 0
ioport_set_pin_level(EXT1_PIN_5,1); //DB0 = 1
delay_ms(2);
//Entry mode set
ioport_set_pin_level(EXT2_PIN_5,1); //DB2 = 1
ioport_set_pin_level(EXT1_PIN_6,1); //DB1 = I/D = 1, Assign cursor moving direction. (increment/decrement)
ioport_set_pin_level(EXT1_PIN_5,1); //DB0 = S = 1, Enable the shift of entire display (entire shift off/entire shift on).
//initialization end.
void sendChar(void)
////////Do NOT NEED TO DO This stuff as I have already initilized the LCD Screen.
//Function set.
ioport_set_pin_level(EXT2_PIN_5,0); //DB2 = F = 0, F = Display font type (F:5*11 dots/5*8 dots) (probably mean 5*10 dots and NOT 5*11 dots)
ioport_set_pin_level(EXT1_PIN_5,0); //DB0 = B = 0, Blinking of cursor (ON/OFF) off.
//Entry mode set (increment)
ioport_set_pin_level(EXT1_PIN_6,1); //DB1 = I/D = 1 (increment/decrement)
ioport_set_pin_level(EXT1_PIN_5,0); //DB0 = S = 0, Enable the shift of entire display (entire shift off/entire shift on).
//Write 'S' in ASCII:
ioport_set_pin_level(EXT3_PIN_15,1); //RS = 1 //Set the RS bit for writing into the data register.
ioport_set_pin_level(EXT3_PIN_10,0); //DB7 =0
ioport_set_pin_level(EXT3_PIN_6,1); //DB6 = 1
ioport_set_pin_level(EXT2_PIN_10,1); //DB4 =1
ioport_set_pin_level(EXT1_PIN_6,1); //DB1 = 1
int main (void)
board_init();
initIO(); //Setting all the directions of all the pins as outputs.
//INITIALIZING BY INSTRUCTION
delay_ms(50); //Wait more than 30ms after Vdd reaches 4.5V.
//Set up the enable pin (needs to be 0 for writing, but needs to go from High -> Low)
ioport_set_pin_level(EXT4_PIN_6,1); //Enable = 1;
ioport_set_pin_level(EXT4_PIN_6,0); //Enable = 0;
//EightbitInit();
//Send The letter 'S' to the LCD.
sendChar();
