    Dismiss Notice
Why the output is zero??
Discussion in 'Homework Help' started by kostfere, May 26, 2012.
  1. kostfere
    kostfere New Member
    May 26, 2012
    2
    0
    View attachment 64554 View attachment 64555
    Hello everybody, I made in Spice the circuit that you see in the photos.
    The picture with the blue font shows the circuit, and is correct as it is from our professor.
    The other circuit was created by me in Spice and as far as I see they are the same.
    My problem is that when i run simulation is Spice the voltage output (the yellow marker) is zero when it should not be!!
    If you could help me you would also save me!!!
    Thnx a lot in advance!!
  2. kostfere
    kostfere New Member
    May 26, 2012
    2
    0
    also if someone wants to ask something more about the circuit or has an answer and i am not online feel free to contact me on Skype!!
  3. cowboybob
    cowboybob Well-Known Member Most Helpful Member
    Oct 22, 2011
    3,022
    477
    James Island, SC
    Have you considered the effect of your grounding schemes?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,592
    477
    L.A., USA Zulu -8
    I believe you have the N-channel and P-channel MOSFETS interchanged (look at the N and P designations). The symbol your professor used for MOSFETs is not common and is drawn with the arrow in the source lead (similar to a BJT symbol having the arrow in the emitter lead) instead of in the substrate lead as your symbols do. When you do that, the arrow directions are reversed.
  6. panic mode
    panic mode Well-Known Member
    Nov 8, 2003
    1,637
    38
    mississauga
    in addition to previous comments, you may want to check to circuit, and in particular voltages.
    second image shows four of them (Vdd, Vss, Vin, Vbias) while your schematic only has three.
  7. WTP Pepper
    WTP Pepper Active Member
    Jan 24, 2012
    648
    41
    UK
    If you could draw the circuit in a more conventional standard may help yourself to understand.
Share This Page
