    Dismiss Notice
Which creates more interference, an open loop or a closed one?
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by Triode, Jul 26, 2017.
  1. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    To test a capacitive touch system I would like to generate interference in wires laying along side my wires to the sensing pads. I have a function generator that can go from -10V to +10V. Is the worst case scenario an open line acting like an antenna, but with no current flowing. Or a loop back to ground, so that it is fluctuating in voltage and current?
    Thanks!
  2. RadioRon
    RadioRon Well-Known Member
    Oct 7, 2005
    1,755
    53
    BC, Canada
    ONLINE
    Usually a loop is worse. Most of the coupling in the side-by-side scenario is magnetic. It is somewhat dependent on the impedances involved. If there is a relatively low impedance load on your touch system, then magnetic, but if the impedance loading those wires is high, then I would swing over to considering the E field coupling to be the stronger interferer. However, a loop with a termination resistance might still be effective for both, and you can tune the termination resistor to get the worst case effect.
    • Thanks Thanks x 1
  3. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    Thanks, I was able to verify that the shielded cables make a huge difference. The odd thing is that I found that if you have another cable along side the unshielded cable and you touch that, even somewhere that isn't near the sensing cable, it also increases the capacitance. It seems like that would just be like a really weak capacitor added in series and too far from the measurement to show up, but it was only a little weaker than touching the first wire.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ci139
    ci139 Active Member
    Apr 12, 2012
    404
    34
    there was one(=1) occasion where some 20m (66ft) - side to side - parallel run of L,N,GND and shielded data cable generated about ~125V/MΩ in cable shield
    the shield was N/C at far end 100m(300ft) -- the data transmission was NOT affected by this "hot plugging flasher indicator" setup (RS422)
Share This Page
