What's the problem of the lcd by using 8051?
Chalidier
Hi everyone,
I am interfacing lcd (JHD 162A) using 8051(89c51). The lcd's lamp only lit up otherwise nothing is displaying on the lcd.
i have checked all the connections to the lcd and they are good.
I wrote the code on keil uvision4
please tell me the problem!
your help is greatly appriciated
here is my code:
  1. #include<regx51.h>
  2. void lcdmd(unsigned char value);
  3. void lcddata(unsigned char value);
  4. void busyflag();
  5. void delay(unsigned char value);
  6. sbit rs=P2^0;
  7. sbit rw=P2^1;
  8. sbit e=P2^2;
  9. sbit busy=P1^7;
  10. sfr ldata=0x90;
  11. int main(){
  12. P0_2=0; //just for checking
  13. //initilization
  14. //step 1
  15. delay(20);
  16. rs=0;
  17. rw=0;
  18. P1_7=0;
  19. P1_6=0;
  20. P1_5=1;
  21. P1_4=1;
  22. e=1;
  23. delay(200);
  24. e=0;
  25. //step 2
  26. delay(10);
  27. rs=0;
  28. rw=0;
  29. P1_7=0;
  30. P1_6=0;
  31. P1_5=1;
  32. P1_4=1;
  33. e=1;
  34. delay(200);
  35. e=0;
  36. //step 3
  37. delay(200);
  38. rs=0;
  39. rw=0;
  40. P1_7=0;
  41. P1_6=0;
  42. P1_5=1;
  43. P1_4=1;
  44. e=1;
  45. delay(200);
  46. e=0;
  47. //step 4
  48. delay(100);
  49. busyflag();
  50. rs=0;
  51. rw=0;
  52. P1_7=0;
  53. P1_6=0;
  54. P1_5=1;
  55. P1_4=0;
  56. e=1;
  57. delay(200);
  58. e=0;
  59. delay(100);
  60. rs=0;
  61. rw=0;
  62. P1_7=0;
  63. P1_6=0;
  64. P1_5=1;
  65. P1_4=0;
  66. e=1;
  67. delay(200);
  68. e=0;
  69. // lines and font
  70. delay(100);
  71. rs=0;
  72. rw=0;
  73. P1_7=1;
  74. P1_6=0;
  75. P1_5=0;
  76. P1_4=0;
  77. e=1;
  78. delay(200);
  79. e=0;
  80. delay(100);
  81. rs=0;
  82. rw=0;
  83. P1_7=0;
  84. P1_6=0;
  85. P1_5=0;
  86. P1_4=0;
  87. e=1;
  88. delay(200);
  89. e=0;
  90. delay(100);
  91. rs=0;
  92. rw=0;
  93. P1_7=1;
  94. P1_6=0;
  95. P1_5=0;
  96. P1_4=0;
  97. e=1;
  98. delay(200);
  99. e=0;
  100. delay(100);
  101. rs=0;
  102. rw=0;
  103. P1_7=0;
  104. P1_6=0;
  105. P1_5=0;
  106. P1_4=0;
  107. e=1;
  108. delay(200);
  109. e=0;
  110. delay(100);
  111. rs=0;
  112. rw=0;
  113. P1_7=0;
  114. P1_6=0;
  115. P1_5=0;
  116. P1_4=1;
  117. e=1;
  118. delay(200);
  119. e=0;
  120. delay(100);
  121. rs=0;
  122. rw=0;
  123. P1_7=0;
  124. P1_6=0;
  125. P1_5=0;
  126. P1_4=0;
  127. e=1;
  128. delay(200);
  129. e=0;
  130. // I/D S
  131. delay(100);
  132. rs=0;
  133. rw=0;
  134. P1_7=0;
  135. P1_6=1;
  136. P1_5=1;
  137. P1_4=1;
  138. e=1;
  139. delay(200);
  140. e=0;
  141. P0_3=0; //just for checking
  142. //initilization ends
  143. lcdmd(0x0E);
  144. lcdmd(0x06);
  145. lcddata('P');
  146. lcddata('h');
  147. lcddata('a');
  148. lcddata('s');
  149. lcddata('e');
  150. lcddata('1');
  151. lcdmd(0xC0);
  152. lcddata('P');
  153. lcddata('h');
  154. lcddata('a');
  155. lcddata('s');
  156. lcddata('e');
  157. lcddata('2');
  158. while(1){
  159. if(P3_1==0){
  160. lcddata(' ');
  161. lcddata('o');
  162. lcddata('n');
  163. }
  164. else{
  165. lcddata(' ');
  166. lcddata('o');
  167. lcddata('f');
  168. lcddata('f');
  169. }
  170. if(P3_0==0){
  171. lcdmd(0x86);
  172. lcddata(' ');
  173. lcddata('o');
  174. lcddata('n');
  175. }
  176. else{
  177. lcdmd(0x86);
  178. lcddata(' ');
  179. lcddata('o');
  180. lcddata('f');
  181. lcddata('f');
  182. }
  183. }
  184. return 0;
  185. }
  186. void lcdmd(unsigned char value){
  187. busyflag();
  188. ldata=value;
  189. rs=0;
  190. rw=0;
  191. e=1;
  192. delay(200);
  193. e=0;
  194. return;
  195. }
  196. void lcddata(unsigned char value){
  197. busyflag();
  198. ldata=value;
  199. rs=1; //data register
  200. rw=0; //write
  201. e=1;
  202. delay(200);
  203. e=0;
  204. return;
  205. }
  206. void busyflag(){
  207. rs=0;
  208. rw=1;
  209. busy=1; //input
  210. while(busy==1){
  211. e=0;
  212. delay(200);
  213. e=1;
  214. }
  215. return;
  216. }
  217. void delay(unsigned char value){
  218. unsigned int i,j;
  219. for(i=0;i<value;++i)
  220. for(j=0;j<1275;++j);
  221. }
I'm not diving into your code just yet.
First things first, have you got the contrast set up right?
Secondly, post us a pic/diagram of your wiring.
Thirdly, don't try to do "on" and "off" displays or anything dynamically to start with. Wait until you have good code with a readable display first, so just try to display something like "Hello World" on the first line and then sit in a while loop.
I see problems in your code from a quick glance over it.
It looks like you're using 4bit mode but you aren't shifting your data in lcddata() and lcdmd().
Also you're trying to do the initialisation routine by bitbanging, but why not just use the lcdmd() functions?
Here are some extracts from an HD44780 library I've used to help you get further, I've tried to use your code function names/style where applicable as well to help you understand:
void lcden(void) {
 e = 1;
 delay(1);
 e = 0;
void lcddata(unsigned char value) {
 ldata=((value>> 4) & 0x0F);
 lcden();
 ldata=(value& 0x0F);
 lcden();
void lcdmd(unsigned char value) {
 rs=0;
 lcden();
 lcden();
void lcd_clearDisplay (void) {
  lcdmd(0x01);
void lcd_init (void) {
  e = 1;
  rs = 0;
 rw = 0;
 //Initialization of HD44780-based LCD (4-bit HW)
 lcdmd(0x33);
 delay(4);
 lcdmd(0x32);
 delay(4);
 //Function Set 4-bit mode
 lcdmd(0x28);
  //Display On/Off Control
  lcdmd(0x0C);
  //Entry mode set
  lcdmd(0x06);
  lcd_clearDisplay();
  //Minimum delay to wait before driving LCD module
  delay(200);
void lcd_home (void) {
  lcdmd(0x02);
void lcd_2ndrow(void) {
  lcdmd(0xC0);
void lcd_printstring(char *text) {
  do
    lcddata(*text++);
  while (*text != '\n');
void lcd_printHelloWorld (void) {
  lcd_home();
  lcd_printstring("Hello World\n");
  lcd_2ndrow();
  while(1);
Use lcd_init() to do the initialisations, then simply call lcd_printHelloWorld();
