What`s the torque of my stepping motors?
Charon102
Hello
I own two stepping motors which I collected from old HP laser printers.
They are from the same type : PM60-H418Z21B RH7-1094 AGEF from Canon.
There isn`t more written on the label.
Each stepper is 4 cm high, has a diameter of 5.7 cm and a flange for mounting. I estimate the weight of one motor to 0.3 kg. Both are unipolar and each has 6 wires.
I`ve already determine the middle-wire with my multimeter and now I want to know the correct current and amperage of the stepper. How can I find that out?
I didn`t find any information or datasheet in the i-net. Somewhere I`ve read that it is a 4 Watt motor.
What`s about the tourque of the motor ? Is it possible to move a 8 or 9 kg robot with both steppers (slow) ?
Greetings Charon
Do they look like this ..
all the way down to the bottom of the page..
Hello
They look like the KP6AP. The propotions are the same, but I can only guess the diameter and height of the KP6AP. Perhaps the motor on the picture is much larger then mine.
My stepper motor has also a diffrent flange and a plastic gear wheel on the drive shaft.
There is written on the label of the KP6AP that it uses 12 V.
Is this 12 V for each coil or for the whole motor ?
How can I find out the max. torque of my steppers?
Greetings Charon102
is this a 6 wire motor?
12V is what can be used on the motor
during my stepper motor experience i have found that if you hold the present step take another then drop the last.. that this "holds" a lot better..
if you have a 6 wire stepper the wires
A=orange
B=blue
C=yellow
D=red
+=white
+=black
This is a sample code from my stepper motor driver program..
For x := 1 to 100 do
 Begin
  AH; DL;
  CH; AL;
  BH; CL;
  DH; BL;
end;
where AH BH CH DH means "active"..or energized...
Notice that i activate A , deactivate D, then activate C then deactivate A
